Farmall 300 Rockford clutch finger adjustment
Posted by Zachary Hoyt on July 19, 2012 at 15:50:28 from (74.47.48.18):
I am getting ready to put the new used clutch disk and pressure plate from D Slater on the flywheel. I looked up the instructions in my 1958 I&T manual and it said that with the upper plate and friction plate at .851" the clutch fingers should be set to 2-7/32". This was fine till I looked at both the old and the new pressure plate assemblies and was unable to find the three holes to put bolts in to compress the springs. Currently the spacing is approximately .96" which it seems to me would throw the finger height way off. If anyone can advise me what to do I would very much appreciate it.
Zach
