Re: Farmall B Generator Belt Starting Problems
Posted by gene bender on July 20, 2012 at 05:15:08 from (67.55.226.123):
In Reply to: Farmall B Generator Belt Starting Problems posted by tshlance on July 20, 2012 at 04:53:22:
Start with the sw on top of the starter. Then refresh the starter brushes ect. Gen belt has nothing to do with starting engine. Mite also need to put new 1ga cables on.Just because the connections are clean doesent mean the cables are good. The B with 6v will start inall kinds of weather but things need to be in good shape. Ive had those tractors for 50 plus yrs and have 10 now As and Bs,BNs. Quick check is when you try to start feel the connections on both ends of your cables if you find one warm at the connection that is a bad cable usually.
