Re: Aftermarket brakes on H
Posted by rustyfarmall on July 21, 2012 at 08:06:49 from (67.55.162.174):
In Reply to: Aftermarket brakes on H posted by BruceS. on July 21, 2012 at 07:55:00:
If they drag only on the top of the drum, you need to adjust that set screw device at the bottom of the brake cover. That is what that device is for.
If the new band is dragging all the way around, you have then adjusted up to tight.
