Re: Calling Janicholson...
Posted by El Toro on July 21, 2012 at 08:49:57 from (108.3.148.85):
In Reply to: Calling Janicholson... posted by BigTone on July 21, 2012 at 08:26:59:
The easiest way to set your valves is to bring No1 piston near the fan to TDC on the compression stroke. Then counting from the fan set valves 1-2-3 & 5. Then rotate the engine 360 degrees and then adjust valves 4-6-7-8. When setting the valves cold add .003" to the hot clearance. Here's an example: .014" hot set the valves at .017" cold. Hal
