Re: Butterfly valve sticking on H
Posted by Wayne Swenson on October 03, 2000 at 20:28:24 from (206.9.159.225):
In Reply to: Butterfly valve sticking on H posted by Farmall Ed on October 03, 2000 at 18:02:05:
1. Did you put the taper of the throttle valve in the correct direction?
2. Before you tightened the screw, did you back off the idle RPM adjustment to allow you to center the valve in the carb venturi (throat) while sliding the throttle shaft back and forth?
3. Did you put Loc-Tite on the screw threads?
4. Are you sure the governor shaft tang is engaged in the throttle shaft notch?
Hope these suggestions help you out.
Post A Followup
: Re: Re: Butterfly valve sticking on H
