Posted by farmallhal on July 21, 2012 at 15:45:29 from (76.4.182.42):
In Reply to: Re: Super C question posted by Brett Helmkamp on July 21, 2012 at 15:02:49:
I crank started my Super C for the first year I owned it without any issues as the charging system was totally wrecked in every mode. If done correctly it isn't an issue. If it is still an original 6 volt positive ground tractor you really need to make sure everything that is related to the starting and charging circuits are shinney clean and bright at every connection. Also, I use 00 size cable with soldered terminals for the battery cables on all my 6 volt tractors. The factory ground which is in the battery box using the instrument panel base is poor at best as it passes through a lot of chassis before reaching the starter. For a test run a good size cable to one of the starter to frame mounting bolts for the positive ground connection. I have found the battery voltage needs to be 6.2 - 6.3 generally for easy starting. Anything less just doesn't seem to work well. A weak or battery with just a couple years of age can certainly be suspect if it can't be totally charged. Your other components like the generator and voltage regulator are for charging the battery and a fully charged battery should start your tractor regardless of their condition. I recently found the push-pull switch a culprit on a 140 as too it's starting issues. Check the voltage coming out of that switch on the coil side as it should be the same as the battery voltage and if not you don't have enough current to excite the ignition components. Your thoughts on the starter switch are good but again everything needs to be shinney bright and clean. You might take the starter and have it tested also to eliminate it as being defective. NAPA or other good auto parts store generally test them free of charge. Good luck and post back your findings, Hal.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
