Re: replacing 263 gas with a D282 in Farmall 656
Posted by Owen Aaland on July 22, 2012 at 02:52:58 from (216.47.35.161):
In Reply to: replacing 263 gas with a D282 in Farmall 656 posted by GR Gold on July 21, 2012 at 14:10:05:
You will need a front cover from a D656 or early D706 tractor. The rear plate from the gas engine will fit on the diesel but you will need a diesel flywheel from a 656 and a diesel starter. Diesel tractors used two batteries but you may be able to get by with a high amperage battery and heavy cables. You won't be using the ignition circuit but you will need to add the glow plug circuit. If you stay with the 560 injection pump you will need a longer choke control cable to operate the fuel shut off on the pump. You will also need the throttle linkage, diesel fuel filters and connecting pipes, (possible the fuel tank also) and air cleaner to manifold hose/tube. The hood will have the exhaust pipe hole on the wrong side when you switch to a diesel.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
