replacing 263 gas with a D282 in Farmall 656
Posted by GR Gold on July 21, 2012 at 14:10:05 from (75.91.200.140):
I purchased an excellent 656 gas tractor with just 895 origional hours but the engine is bad stuck and has water in the #3 and #4 cylinders. It sat many years with the exhaust uncovered after the owner passed away. I also now have aquired a 1959 diesel 560 that runs like a top with virtually no blowby and the previous owner claims to have had it rebuilt years back. What would be involved in putting the D282 in the 656? Looks like the front motor plate would have to change, although I might be able to drill holes in the frame rails, and the rear motor plate would be different. What flywheel and starter would I have to use? Would I benefit from a later model Standadyne injection pump over the Roosamaster pump on there now, or could the earlier pump be turned up for more fuel and or rpm? The 656 is a 1968 model. Probably need a diesel return fuel line. What else am I overlooking and would anybody else consider doing this? Would this change the value of the 656 tractor or should I rebuild the gas motor? I appreciate all your replies!
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
