Re: replacing 263 gas with a D282 in Farmall 656
Posted by Owen Aaland on July 22, 2012 at 22:55:58 from (216.47.35.146):
In Reply to: replacing 263 gas with a D282 in Farmall 656 posted by GR Gold on July 21, 2012 at 14:10:05:
You might be able to get by using the gasoline flywheel and D560 starter.
The gas flywheel has a little larger diameter ring gear and uses a starter drive with either a 29mm or 32mm OD gear. The diesel starter uses a 32mm OD gear for a hydro tractor and a 36 mm OD gear for a gear drive tractor. The 560 starter will have a 40mm OD gear. I don't know for sure if the 560 starter end frame will bolt in to the 656 housing but the drive problem could be solved but switching to the correct dimensional drive gear.
