Re: Bad noise in 5th gear on M
Posted by Denny on October 04, 2000 at 10:19:46 from (12.4.181.2):
In Reply to: Bad noise in 5th gear on M posted by S-E Michigan Part Timer on October 03, 2000 at 15:35:55:
5th gear in H's & M's isn't a true "Gear Meshing with another gear" so I doubt it's a broken tooth. Almost sounds more like it might be a bearing getting bad on your input shaft causing your constant mesh gears to run together diffently. Or the drive yoke getting loose on the input shaft causing the bearings to loosen up. But then It would seem like it would make the noise in ANY gear or even when sitting still doing PTO work. The fact it goes away under coast is a good thing. If it was a bad bearing or gear it should still keep making the noise.
Post A Followup
: Re: Re: Bad noise in 5th gear on M
