At least nothing real bad happened. Looks like input shaft got chewed on a little bit.
I've got a SM in the shop now that's somewhat apart. Orginally got in there just to clean and re-seal, then I decided the pinion bearing was too loose and the input shaft bearing were too loose so there it is. Needs a clutch anyway.
Another SM I got into had nearly an 1/8 inch groove under one of the bull gears and had obviously eaten a ball or two. It was old damage though and one of axle bearings was a replacement.
I've been replacing the pinion bearings with a Max type that has more capacity. The standard bearing is a 311 and the max type is a 311W. Haven't found a good aftermarket number for the pilot bearing. There's one out there that fits that's basically two ball bearings together. Not sure how it compares to the roller as far as capacity. We put one in an M but haven't used it a whole lot.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
