Posted by Rootsy on July 23, 2012 at 19:52:41 from (174.124.167.104):
Started off with replacing the left side outer axle seal which opened up a real can of worms... Going to be an expensive morning tomorrow... Inner and outer axle bearings, pinion bearings, bull pinion bearings... seals... gaskets... To think she made the 20 mile Mackinac Bridge ride in 2009 and aside from a little oil leaking out of the housing and onto the rim now and again sounded fine... Internally, it sure isn't. Ring / Pinion backlash is about 60 thousandths, minimum, and the roller bearing supporting the end of the pinion was GONE, the rollers were in the bottom of the case. The ball bearing wasn't far behind... Lucky it didn't grenade... Though the right bull gear is newer and tried to eat it's way through the rear-end housing at one point in the past...
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
