Re: govner
Posted by gene bender on July 24, 2012 at 02:59:27 from (67.55.226.123):
In Reply to: govner posted by Jimmy Neal on July 23, 2012 at 18:38:23:
Have yopu set the rod going to the carb as described in the I@T manual. Your problem is not the gov unless the spring hooks are faced the wrong way. Does the input shaft have a lot of slop. Also the carbs butterfly shaft mite have slipped at the input end and is it an original carb or a replacement that has the lever on the input end adjustable? How is the rest of the linkage. Are the two springs on the input link correct and free.
