Re: 806, little to no power steering.. I'm lost!
Posted by caterpillar guy on July 24, 2012 at 06:31:43 from (66.227.141.21):
In Reply to: 806, little to no power steering.. I'm lost! posted by Bobcat698 on July 24, 2012 at 06:08:56:
If this happened after the steering work it is still a prime or air issue if it happened since then after steering was working it is probably the pump. there should be a slice in the lines going to the front by the frame rail opne them up and see if your getting oil there. I use this location as it is easier than at the front under the radiator. they are the same lines just you can slip a hoe on there to catch the oil. There is a plug on the back side of the MCV put a gage on there and see if your getting about 1500PSI at rated engine speed.
