Posted by Bobcat698 on July 24, 2012 at 06:08:56 from (71.13.198.82):
My Farmall 806 has little to no steering assist. It has a wide front end.
It will steer a small amount but it is armstrong steering. Even with the front off the ground it still takes a good amount of force to steer it.
It doesn't steer easier one way compared to the other.
It doesn't help if you raise the RPM's either. The tires will turn a little with the engine off.
The fluid has recently been changed, along with the filter. The 3 point, T/A, and aux hydraulics all work fine, along with the brakes.
Fluid is getting to the steering components up front because recently it started leaking hydraulic fluid by the square plate right below the radiator. We ended up tearing the whole front end out and putting new o-rings on everything. We removed the piston & everything, replacing anything that looked bad. This fixed the leak, but not the steering.
It isn't a priming issue.. We removed the bottom plug on the MCV (facing the step) and started the tractor. Fluid came out quickly but it didn't change the steering at all once reinstalled. We also took out the middle plug, spring, and valve. The orifice on the valve was plugged so we cleaned it out and reinstalled. No change.
I checked the Hydraulic level, even overfilled it by 5 gallons. No change.
We put a gauge on the block right behind the battery on the drivers side.. It read 225-250PSI. Same thing on the bottom port on the MCV.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
