Re: Farmall m wiring issue
Posted by randy hall on July 24, 2012 at 15:56:20 from (216.255.38.144):
In Reply to: Farmall m wiring issue posted by John 37A on July 24, 2012 at 15:47:25:
you need a diode installed as per the diagram. it is back feeding the ignition through the alternator without it.
