Re: Farmall B Fan squeals, cheap fix? Photos
Posted by Jim Becker on July 24, 2012 at 16:46:13 from (173.74.120.222):
In Reply to: Farmall B Fan squeals, cheap fix? Photos posted by David Inman on July 24, 2012 at 13:41:28:
I don't know the dimensions of any of the internal parts of that fan hub. I doubt that anyone else will be able to post them either. But nothing in there is particularly high precision. You should be able to measure existing parts to decide what size washer you need. Looks to me like the major problem is that nobody has oiled it in the last several decades.
You need to clean the bearing surfaces off then decide if the bushings/shaft are a tight enough fit to reuse. You should be able to decide what size/thickness the thrust washer needs to be. It needs to be thick enough to eliminate excessive end play but thin enough to assemble.
Forget about a seal on the back end of the shaft. None is listed in the parts catalog because it isn't needed. It does need to be oiled, as explained in the owner's manual.
Be sure to put it all back together correctly so it doesn't come apart. If it fails, the fan could hit the radiator.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
