Re: Farmall B Fan squeals, cheap fix? Photos
Posted by David Inman on July 24, 2012 at 18:16:39 from (174.39.164.91):
In Reply to: Re: Farmall B Fan squeals, cheap fix? Photos posted by Jim Becker on July 24, 2012 at 16:46:13:
Jim, when you say the thrust washer should be "thick but thin" do you mean how thick the metal is, or the distance by which the washer stands above the hub.
All, What I am failing to understand is WHAT dose the bearing have to do with the end of the spindle rubbing on the back of the fan? Shouldn't the two be far enough apart that they don't rub?
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
