Posted by D Slater on July 25, 2012 at 06:54:08 from (184.15.3.232):
In Reply to: 12 volt option posted by Notjustair on July 24, 2012 at 20:12:16:
USA non diesel tractors that size didn't come with 12 volts until the 400 LP. During 1957 all 450 tractors got the 12 volts. MD used two 6 volt batteries with a 12 volt system. If the 50 M has a voltage regulator, a look alike generator and voltage regulator from the late fifties or early sixties along with a light bulb change was about all that was needed exept a resistor or coil made to use without a resistor. Starter could have work or be a regular M one. Also I have installed 12 volt starters from some later models on 2 bolt M drive housings.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
