Re: Is it worth it to restore a Farmall 1947 H
Posted by old on July 26, 2012 at 15:50:30 from (209.86.226.19):
In Reply to: Re: Is it worth it to restore a Farmall 1947 H posted by Mike James on July 26, 2012 at 15:28:33:
Is it worth the cost to restore heck no but to bring it back to life good chance it can be done with out a lot of $$ other then maybe the tires if you buy them new at around $400 or more each. If the exhaust has been covered good chance it can be got up and running in a week or so. I would first check to see if the engine is locked up or not. Then if it is or is not I would fill the cylinders with ATF and let ti sit a few days. As for the 12 volt battery will not hurt a thing to use one to spin it over and after a few days of ATF soaking clean up the points and give it some gas and see what happens
