Re: Wico Magneto question
Posted by old on July 28, 2012 at 16:07:45 from (209.86.226.40):
In Reply to: Wico Magneto question posted by JRSutton on July 28, 2012 at 13:10:47:
I almost bet you messed with the points just enough to get some dirt/oil on them so no spark. Clean the points and try again. Now then would you believe you might get better answers on that mag over in the JD forum since many of the old Johnny poppers used that same mag
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
