Wico Magneto question
Posted by JRSutton on July 28, 2012 at 13:10:47 from (75.130.109.233):
ok - so it's not IH - it's the magneto on the wisconsin egnine on a new holland baler - but the brand shouldn't matter, just more of a general magneto question.
I'm trying to get the engine started - it sat for 15 years.
2 cylinder engine. I HAD spark on both plugs this morning before I started going over the engine...
Stuck valves - crusty carburetor - old oil - etc etc. At some point I opened the mag to clean the points (foolishly I guess - should have left well enough alone).
In no longer have spark.
Nothing - neither plug - totally dead.
Now - I also, rather foolishly, turned the engine over for a while using the electric starter - with the plug wires disconnected by mistake.
Not a mag expert here - I've heard running a mag ungrounded like that can be a real bad thing - but I'm not sure HOW it's a bad thing - what goes wrong if you do that?
I'm thinking I either messed up the points in cleaning them - or I burned something out in the mag by running it with no plugs...
Thoughts?
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
