Re: Whats a good Gravity flow filter
Posted by Bouncer on July 29, 2012 at 11:34:21 from (68.28.137.228):
In Reply to: Re: Whats a good Gravity flow filter posted by old on July 29, 2012 at 10:38:19:
If you think the bowl and screen catches all the fine material, then you are incorrect. That was 1910-1960 technology. Today's modern filters, both oil and fuel, catch particles down to micron size. The reason they get plugged up and reduce flow, is because they are filtering everything the sediment bowl misses. Which is often micron size particles that you can not easily see. You can do whatever you want on any of your own tractors, but let me ask you this. Would you run a sediment bowl system on your modern vehicle? I have nothing against them, but only use them on a restored tractor or until one starts leaking. When it starts leaking on a working tractor, they get pulled off and replaced with a ball valve and inline filter. I can change that inline filter and be back running before you can even get the sediment bowl off, and cleaned out.
