If the points are open, 12 volts thru the resistor, coil and dist is normal.
Try turning the crankshaft just enough to close the points then take your voltage readings again. You should get battery voltage on the switch side of the resistor, approx 5 - 7 volts on the other side of the resistor and at the coil "+" terminal, and ~0 volts on the coil "-" and distributor terminals.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
