h farmall 12 volt conversion
Posted by paul vroman on August 02, 2012 at 18:44:09 from (74.206.62.233):
I put a 12 volt conversion alternator on my super h farmall. I put 12 volt battery juice to the new resistor and checked through voltage with a meter. The voltage through the resistor, coil and distributor remains 12 volts. Is this normal? If I start the engine with the alternator voltage will it destroy the points?
