Re: h farmall 12 volt conversion
Posted by John T on August 03, 2012 at 05:37:29 from (216.249.82.117):
In Reply to: h farmall 12 volt conversion posted by paul vroman on August 02, 2012 at 18:44:09:
Is it normal????? NOT USUALLY
Usually the points are closed, they only open when a piston is near TDC to fire a plug, and engines dont usually stop with a piston in that position.
As my friend Bob M noted if the points are closed (which they usually are when a tractors setting there not running) theres current flow from the switch to and through the resistor,,,,,,to and through the coils LV primary,,,,,,,,to and through closed points to ground so theres an I x R Voltage Drop (around 6 volts) across the resistor leaving 6 on a 6 volt coil. If theres no current flow (points open) theres no I x R voltage drop as 0 x 1.5 ohms = 0 volts
John T
