Re: Cub Clutch/bent shaft
Posted by Janicholson on August 05, 2012 at 12:48:33 from (96.24.99.126):
In Reply to: Cub Clutch/bent shaft posted by patsdeere on August 05, 2012 at 12:31:57:
.010" would be the outside!! There is no joint in the shaft, it goes directly into the trans, as the maint input shaft. 351534R2 is the part number, I would have it straightened, or determine if it is the front trans bearing that may be remiss. If it is unsupported when you are "testing" it may not be bent at all, or it might be just slightly out. Support the pilot journal, and recheck. jim
