Cub Clutch/bent shaft
Posted by patsdeere on August 05, 2012 at 12:31:57 from (76.103.237.94):
So I was splitting a friends cub to replace the rear main and when I was starting to put it back together I notice the shaft from the transmission appears to be slightly bent. How bent can it be and not be a problem? It will simply be a parade tractor and sit in a business. From top high to bottom low it is about 3/8"-1/2".
Thanks.
