Re: Cub Clutch/bent shaft
Posted by rhtx55 on August 05, 2012 at 13:25:51 from (207.119.62.8):
In Reply to: Cub Clutch/bent shaft posted by patsdeere on August 05, 2012 at 12:31:57:
The bent shaft will only cause more problems with more expensive gears etc. down the road, parade tractor or not. I would remove it & have a machine shop check it for straightness. I would also replace the pilot bearing (bushing) & the front tranny mainshaft bearing, and seal you don't want this shaft "wobbling" much at all.
