I know it's been a while but I had some time to play today, which is rare (I should have kept at cleaning my garage but that can wait for another day).
Here's what I did. Replaced all the plugs with new one (Autolite 386, gaped .025), no change. So I warmed it up for 10 minutes or so on fast idle and checked the compression. Everything was 85 pounds across the board, which seems a but low to me but it was dead even. The plugs read all the same, ie looked brand new, but that's not a lot of running time.
The miss isn't even, so I don't think it's ignition.
The carb (Zenith) was rebuilt but it has the same problem it had before I rebuilt it, the idle screw has not effect on the engine no matter where it's set, that is it can be seated or run way out (4 plus turns) and nothing happens. I even had a spare screw, no help.
It's has to be the carb right? I sprayed it down with starting fluid and nothing happened so it's not an obvious air leak. I couldn't find any leaks around manifold either.
I think might pull the crummy old Marvel off my BN an throw it on to see what happens.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
