Posted by gene bender on August 05, 2012 at 15:18:10 from (67.55.226.123):
In Reply to: Farmall A Misses posted by kopeck on August 05, 2012 at 14:16:13:
Take a timing lite and clamp starting with #1 wire watch fire should not be intermittent then go to next wire and continue all wire should have fire steady no missing then going again. this will also check the wires and if you have a dist it can mean bushings are bad letting shaft wobble your problem isnt gas its fire. That doesent mean the new plugs are perfect not too uncommon.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
