Re: 350DU steering swap
Posted by CNKS on August 05, 2012 at 17:09:51 from (216.144.104.128):
In Reply to: 350DU steering swap posted by strikefalcon on August 05, 2012 at 15:31:48:
The power steering is a supplement to the manual steering, ie you have to have the manual steering box to use the power steering.
Today's Featured Article - Buying your first tractor: The People You Buy From - by Chris Pratt. If you are a first-time buyer, chances are that you are likely to take the word of the seller on things. This is where the problems start... You have reviewed your implement needs and determined the size of machine that will fit the bill and even made a list of the most desirable models. You checked on the availability of a 3-point hitch for the machines on the list and advertised in your local classified paper with so ... [Read Article]
