350DU steering swap
Posted by strikefalcon on August 05, 2012 at 15:31:48 from (184.20.100.20):
How "bolt in" would swapping power steering with manual steering on my 350DU's be. The "good looking, good running" one has a shot manual steering box. The "super hard starting. worked hard and put away wet" one has a good power steering set-up. Or
would it be easier to buy a rebuilt manual box and swap it out on the good one?
Thanks
Loren
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
