There might be a broken bearing in the final drive. The balls can (and often have) jambed between the bull gear and case. If forced, it will break the bottom out of the housing. Use a hydraulic jack ubder that axles housing (out toward the end where the axle comes out. Use good blocking and cribbing to assure a solid lift. Watch the axle as the pressure is taken off the tire, and transferred to the jack. The axle and wheel should remain straight, and not be loose. If play is found, the inner axle bearing is likely bad. Jim
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
