1949 RR wheel will not turn
Posted by Hawes Farmall on August 05, 2012 at 19:24:07 from (174.231.140.66):
I had a 1949 Farmall M gave to me and the right rear wheel will not go forward. We jacked up the back and tried spinning the wheel and it spun. But we let it back down and tried pulling it with the truck and it won"t turn. The left one turns fine. Does anybody know what I could be? It has the lambert brake system on it if that helps.
