Re: 350DU steering swap
Posted by CNKS on August 05, 2012 at 19:56:56 from (216.144.104.128):
In Reply to: Re: 350DU steering swap posted by Janicholson on August 05, 2012 at 18:36:46:
Jim, Is the worm gear, etc different on the PS equipped 350U compared to no PS? That is what I meant when I said he had to have it. I was comparing it to my 460U which has the PS pump attached to the hyd pump in the "belly" of the tractor and has what I think are the same manual parts, perhaps not.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
