Posted by Janicholson on August 05, 2012 at 18:36:46 from (96.24.99.126):
In Reply to: 350DU steering swap posted by strikefalcon on August 05, 2012 at 15:31:48:
They can interchange.In my opinion the two are different, and have very different components. They do mount to the tractor in the same holes. A different steering wheel is used. and a priority valve is needed from the donor tractor, as well as the lines. Good luck it should be pretty easy, but will have things pretty far apart. Jim
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and
... [Read Article]
Latest Ad:
[More Ads]
