I assume when you jacked it up and turned the wheel the opposite wheel turned backward? Something ahead of the differential (or in the differential) must be bound up. Not the brakes. They have to turn with the axle. And you could have multiple problems such as a broken pinion shaft. I guess you will have to tear into it and find out. But if the wheel turns when jacked up it's NOT the brakes.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
