The resistor you got from NAPA goes in the wire between the ignition switch and the coil. It will only work properly there.
Unfortunately it sounds like you put it in the wrong place, AND it was too little too late. The coil was already damaged from running on 12V for so long.
You need a NEW coil now, too.
Resistors are a funny thing. They DO reduce voltage but not in an easy-to-understand way. You can use a resistor of the correct size on a fixed load like an ignition coil, but on a variable load like an entire tractor, they won't give you a reliable 6V output.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
