Farmall Super H 12v Batt only
Posted by Dragonclaw on August 04, 2012 at 17:15:54 from (69.11.163.106):
My grandad has a Farmall Super H and he use a 12v Batt in it. None of the rest of the tractor has been converted to 12v and it still has the original generator on it. I know the voltage regulator, Coil, and Distributor need to run on 6V instead of 12 so I was trying to wire it so that they would.
What i did was take the wire running from the started to the AMMETER and place a resistor there. In my mind that should make everything past that run at the desired voltage. Thing is if i use my volt tester to check the voltage at the regulator I'm still seeing 12v. So what am i doing wrong?
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
