Re: 1949 RR wheel will not turn
Posted by Owen Aaland on August 07, 2012 at 07:38:45 from (216.47.35.78):
In Reply to: 1949 RR wheel will not turn posted by rhtx55 on August 05, 2012 at 19:24:07:
Jacking it up has the affect of lifting up the bull gear as the wheel pulls down on the outer end of the axle.
