Hawes Farmall said: (quoted from post at 21:24:18 08/07/12) When on the ground it turned going backwards but won't go forwards. Left wheel turns fine both ways.
If there are pieces of bearing in front of the bull gear they will wedge between the gear and the housing as the gear turn in the forward direction. When in reverse the pieces will stay in front of the gear. Jacking up the axle may lift the gear high enough that it will not catch any of the pieces to pull them under the gear. If you force it forward hard enough it can push the pieces out through the new hole in the bottom of the housing.
This post was edited by Owen Aaland at 19:57:30 08/07/12.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
