Re: 1958 IH350U Hydraulic System need help
Posted by Don H on October 07, 2000 at 14:54:02 from (205.188.195.48):
In Reply to: 1958 IH350U Hydraulic System need help posted by mark on October 05, 2000 at 14:24:55:
Mark, you have gotten good advice from others on your current problem. I can't add anything to what you have already been told, but I do have a '58 350 hi-utility, which is the same as yours except it has 38 inch rubber on the rear and raised front spindles to give it more ground clearance. If you have other questions I'll be glad to try to help. I spent 4 months getting mine in running order after I got it so I have been inside quite a bit of it. I can't promise I know everything about it but I also operated one in the late 50's and early 60's so I have had a bit of experience with them. I hope you will be as happy with yours as I am with mine.
Post A Followup
: Re: Re: 1958 IH350U Hydraulic System need help
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
