Re: air breather cleaning
Posted by Brett Helmkamp on August 11, 2012 at 04:56:49 from (67.236.72.7):
In Reply to: Re: air breather cleaning posted by Nebraska Cowman on August 11, 2012 at 04:45:52:
Do you leave the ATF in during operation? Would you have to worry about any of it getting sucked into carb?
I was told that sometimes if you fill them to the exact level of the line, it can cause a problem. Over the years they have built up a lot of crud in them and as the oil gets into it and then settles to the bottom. It fills the bowl to a higher level and then it can get into the carb.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
