Re: Governor on H Farmall
Posted by rustyfarmall on August 14, 2012 at 08:04:19 from (67.55.162.174):
In Reply to: Governor on H Farmall posted by D Slater on August 14, 2012 at 07:53:28:
Correct. "splash system" was probably the wrong term to use. Probably should have used "intermittent" instead. I do know IF the system is working, you WILL know it if you start the engine while the cover is off the governor.
