Re: IH 656 Hydro pto, hydraulic and movement problem
Posted by pete 23 on August 15, 2012 at 11:07:27 from (74.32.238.2):
In Reply to: IH 656 Hydro pto, hydraulic and movement problem posted by shade2 on August 15, 2012 at 08:53:44:
I never had one fail that did not ruin the shaft along with the splines in flex plate, not that you could not be lucky and just strip out or break the flex plate. Later model tractors went to a spring cushioned plate like the regular clutch tractors have. Problem is you need a different flywheel or a very good machinist to convert to that. Low hour failures were counted off as a misalignment problem between engine and transmission. High hours, just wear and tear. If you could get the hydro repaired for $2800 I would say that is a very reasonable figure.
