IH 656 Hydro pto, hydraulic and movement problem
Posted by shade2 on August 15, 2012 at 08:53:44 from (162.40.46.190):
656 Hydro will run, but has no movement. We were cutting hay and the disc mower's safety pin came loss causing the disc mower to come up and hit the tractor. The pto and hydraulics do not work. No movement at all! Tried to drive the tractor to the trailer, but no movement from the tractor either. It still runs like a top, but put it in gear and nothing happens. Heard it might be the flex plate?? We were also told it could be the transmission........mechanic said 5K to fix the transmission.....so not worth it, if that is the case. Any information is appreciated! Thank you
