Wouldnt a cooler intake manifold help HP because of greater density of air/fuel charge? My guess would be fuel related, could try raising the float level a bit and see if anything changes. I would think you may want to do away with the in-line filter all together, but at least remove it and retest without it. I imagine you are running a paper air filter not the stock oil bath ? Otherwise it could be restricting through the oil bath, again I would run without it to see if anything changes.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
