Posted by LarryM on August 15, 2012 at 10:59:09 from (146.151.183.162):
I have a C-281 in a Super M that I have tuned up pretty good. The high idle is at 1600 and the 540 PTO horsepower is 66. The issue I face is that it holds 66 hp for about 30-50 seconds and then it slowly loses 4 horsepower at 540 over the course of the next 50-90 seconds. If I let it sit and run at high idle for a few minutes it will run at 66 hp for 30-50 seconds. I have all the holes in the sediment bowl assembly bored out and I have a 5/16" hose and fuel filter going down to the carb. If I pull the plug on the carb fuel runs out fast and keeps on running fast when the bowl gets empty. The ignition & valve clearance have been checked and rechecked. I only have two ideas left. 1. The 450 three rib manifold is getting to cold and the fuel is not atomizing. 2. I need to try an elctric fuel pump. Anyone see this before?
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
