Re: torque specs on oil pan
Posted by sflem849 on August 15, 2012 at 18:14:49 from (69.197.84.39):
In Reply to: torque specs on oil pan posted by rustred on August 15, 2012 at 17:25:48:
rustred said: (quoted from post at 17:25:48 08/15/12) is that for a 5/16 bolt?
Sorry, that is for a 3/8" (9/16 socket) Gr 3 5/16" NC is 17 ft/lb and Gr 5 is 19 ft/lb. I use the Gr 3 spec for all dot head bolts unless they have different markings.
http://www.engineershandbook.com/Tables/torque.htm
I just found this one with a quick Google search, but the one I printed off and keep in the toolbox has what wrench size corresponds with what bolt size. I can be a dummy on that somedays. :roll:
That chart is tricky as it is dry torques. YOU SHOULD USE A CHART THAT USES WET TORQUES!!!
This post was edited by sflem849 at 18:23:32 08/15/12.
